Reception problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by MikeMM, Feb 4, 2005.
  1. MikeMM
    MikeMM
    Feb 4, 2005
    2
    I have recently purchased a Toshiba D-R1 but I am experiencing diagonal lines across my TV screen when tuned into channel 4. All other channels are ok and when I switch the recorder off the picture quality is fine. Could any one help?
  2. JayCee
    JayCee
    Jan 20, 2004
    20,222
    Lanarkshire
    +1,936
    Try moving the Tosh physically further away from your Tv and see if that stops or reduces the interference.
  3. JethroUK
    JethroUK
    Dec 5, 2004
    1,141
    maybe r/f frequency is too close to channel 4 & needs tweaking away from it
    you can tell if it's this by unplugging any aerial from the recorder and plugging it straight back to TV - now try channel 4 with the recorder on - if the interfernce has gone - that's what it is
  4. JayCee
    JayCee
    Jan 20, 2004
    20,222
    Lanarkshire
    +1,936
    How can it be? It does'nt have an Rf modulator!
  5. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
    I had a similar problem with my XS32, and it turned out to be caused by the RF fly lead coming out of the XS32. While the xS32 was just looping the RF through, the lead supplied is poor quality, and I was getting interference. Replacing this with a good RF fly lead solved the problem.
    For me, it was ITV which was really bad; Channel 4 only had a little interference...
    Mark
  6. JethroUK
    JethroUK
    Dec 5, 2004
    1,141
    If it doesn't have R/F out, then that's not the problem
  7. PanicLord
    PanicLord
    I'd go with moving the unit further away. I've been having major interference problems on my Pan DMR85 (which is an amazing machine) and it came to me in a flash of inspiration last night that the hard drive in it is basically a big magnet, and it was only 20cm away from the TV or so.
    Moved it further away - picture is now clear! :clap:
