Receivers with audio streaming capability?
Discussion in 'AV Receivers & Amplifiers' started by Flipper, Jun 4, 2005.
  1. Flipper
    Flipper
    Nov 27, 2003
    209
    28
    +27
    I've been thinking about getting a slimp3/squeezebox to stream audio files from my pc. Are there any receivers that can do the same job? I have limited space for another "box" so a receiver upgrade would be just the job.
    Cheers,
    Flip.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I believe Onkyo receivers with the NetTune function might fit your requirement. :)
  3. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,422
    63
    Andover
    +159
    There's a big thread(s) under MP3 / Digital music about streaming audio from PC's to AMP's, I'd suggest you read that as a starting point. But it would appear that functionality is pretty limited for example - I use Itunes and wirelessy transmit to a airport express that hooks into the AMP but I don't get a playlist display, which is OK for me because I create and choose the playlist on the computer beforehand.
