Receivers with a phono (turntable) input? (just Denon?)
Discussion in 'AV Receivers & Amplifiers' started by jabberwock1977, Jun 21, 2004.
Tags:
  1. jabberwock1977
    jabberwock1977
    I'm looking into buying a reciever for both home cinema and music and one requirement is that it has a phono input for a turntable. From what I can see that means I'm limited to Denon... anyone know an others? Budget £200 - £400ish.
    Thanks...
  2. jabberwock1977
    jabberwock1977
    It looks like a few of Sony's have a phono input. I'd never really considered Sony for an AV receiver as i didn't think it was one of the major players. Anyone have any experience with them? Perhaps the DB790? http://www.avland.co.uk/sony/strdb790/index.htm
    It'll probably be for some Kef eggs or Sib & Cubs
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Being limited to Denon isn't necessarily a bad thing, their budget receivers are eaily among the best available. :)
  4. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    If you dont want a Denon, then get yourself a cheap phono stage to go with any amp you select. Do a search as theres several on the market.
  5. jabberwock1977
    jabberwock1977
    True.. i just don't like having my options limited. Not sure i can afford the 2803 but may consider the 1804.
    I may do that Karkus but its not ideal and means using up an other mains socket.
  6. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    You could try something like a project phono box around 30 quid I think, and it will probably sound better than any built in phono stage aswell.
  7. jabberwock1977
    jabberwock1977
    Yup.. i could do that SS.
    However having researched that Sony 790 that i stumbled across yesterday I think it might be exactly what I'm after.
    Now must arrange a demo... anyone know a shop in Central London that stocks that receiver and Sib/Cubs and preferably Kef eggs as well?
