receivers and AVstands
Discussion in 'AV Receivers & Amplifiers' started by Andywilliams, Dec 16, 2003.
  1. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,090
    notts.
    +64
    Hi folks
    Didn't know where to post this,Anyway my tv is in the corner of my lounge with the fronts at either side of the tv i have no room either side for a wider stand than the tv stand, so to fit my new receiver(harman kardon avr8500) in iam having a taller stand made which will make my tv 26'' off the floor will this look ok?is there a given height for tv veiwing.Also having to place the amp on the bottom shelf to prevent staining of the tvs picture the receiver will be in a open stand with plenty of room around it with a 4'' gap above it.There must be other people with big receivers under their tvs.
    Cheers Gonzo.:)
  2. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    Portsmouth / Middle East
    +77
    You'll be fine gonzo. Just dont turn it up too loud ok!
