Curtis2000
Some advice needed please...
Regarding the content on this page: http://www.thx.com/consumer/home-entertainment/home-theater/surround-sound-speaker-set-up/
Which is better, 7.1 Surround Sound Speaker System Set Up or Dolby® TrueHD or DTS-HD Master Audio™ Set Up? I'm building a house and I didn't see the later one just the 7.1 setup, so I was having them wire it for the 7.1 configuration since we will have 7.1 wiring, where the back speakers are in the middle, next to each other, firing directly at my head. I thought that was odd when I originally saw this before since you usually always see them on the sides, pointed in the middle. But I trusted what I saw since it came from THX. Did I mess up? Is the later Dolby setup better? I don't know much about sound and if it is like Blu-ray vs HD DVD battle, where one will eventually win as the lasting format and I will regret it down the road since it won't exist and having the speakers so close to each other isn't ideal. If I leave it as is, will I not get as good of sound if I don't go with a receiver that is THX certified? There aren't that many.. Seems like I do as the setup I picked, requires THX technology to take advantage of it.
I was trying to do it right and I think I screwed up now.
Curtis
Curtis
