receiver with i.link
Discussion in 'AV Receivers & Amplifiers' started by kifimoto, Nov 23, 2003.
  1. kifimoto
    kifimoto
    is there actually any point in getting a receiver with i.link?
    i'm not that fussy about audio quality so i'm wondering whether i should shell out for the pio ax3 instead of ax5.....
    may be i should go for denon2803?
    any suggestions?
  2. mjcairney
    mjcairney
    Oct 26, 2003
    7,135
    2
    2
    137
    Airdrie, Scotland
    +986
    The only point in getting a receiver with iLink is if you have a DVD player with similar connection.
  3. kifimoto
    kifimoto
    but do you think the i.link audio connection is that far superior to other types of connection...
    i don't know whether i should go for the AX5i or the AX3.....:confused:
  4. aimprod
    aimprod
    Jan 19, 2003
    24
    East London
    it will carry dvda and sacd digitaly, which coax etc.... is not capable of. I guess it depends if you need that.
  5. bobbypunk
    bobbypunk
    All i know is that the vsxax3 is incredibly good ampso go for that (or the 5i but obviously only if you're gonna spend £800-£1000 on your dvd)
  6. Brogan
    Brogan
    Oct 9, 2003
    7,582
    Cary, North Carolina
    +482
    I went for the AX5i over the AX3 because it had iLINK.
    Can't say I can notice any particular difference or improvement over phono or co-ax but the little blue light sure does look pretty....
  7. Paul D
    Paul D
    Dec 27, 2000
    2,737
    Manchester
    +534
    LOL!:D :rotfl: :D
  8. kifimoto
    kifimoto
    i think i'll be going for the AX5i and sevenoaks can do it for 950 (because i've already bought a plasma from them!!!)
    it's an okay price i suppose.....
  9. Brogan
    Brogan
    Oct 9, 2003
    7,582
    +482
    Best Price TV are doing them for about £870 delivered allegedly...;)
  10. Adam M
    Adam M
    Oct 18, 2001
    756
    London
    +19
    as far as I know, phono cable bandwidth is 2mpbs, i-link is 400.
  11. nemo
    nemo
    Nov 19, 2003
    406
    28
    +25
    kifimoto
    Check out Superfi, I just got my AX5i from them on Sunday for £850. Alternatively Empire Direct are doing them for £847 + pp.
  12. kifimoto
    kifimoto
    really? hispek was doing it for 956 and i got sevenoaks to pricematch for me (also because i'd already bought a plasma from them...)
    phew, thanks for the heads up. i'll check out superfi / empire direct!
  13. kifimoto
    kifimoto
    hi nemo, i just looked at the superfi.co.uk website and the AX5i is 1029 squid! did you actually buy it at the shop?
    oh, just checked empire direct and it is indeed 847 +pp
    (AND they've got it in stock - yippee)
    cheers
  14. nemo
    nemo
    Nov 19, 2003
    406
    28
    +25
    kifimoto, Yeah I just went into Superfi and pointed out to them that Empire Direct had it on there web site for £847 + pp and they matched the price on the spot.
  15. ailean
    ailean
    Just got to love price match! ;)
    Managed to get £100+ off a SLR+lens package a few years back, the sales guy couldn't believe the price and phoned the little shop I'd spotted it in, then steped back from the counter said Okay. He still looked stunned as I left the shop. :)
  16. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    You can run atleast 270Mbits down a properly terminated 75ohm BNC cable, as this is what's used for SDI.
  17. kifimoto
    kifimoto
    just called Sevenoaks at Kingston and they won't bulge. They're selling it for 999 squidily. They may price may the hi-spek price which is 956 but not 850. The manager told me to buy it from empire direct.... (i'll probably get it from superfi if they do do the price match!)
    Nemo, which store did you ring up?
    cheers
  18. nemo
    nemo
    Nov 19, 2003
    406
    28
    +25
    kifimoto, got mine from Manchester but I'm sure if one branch can do it for £850 they all can. Don't think Superfi will price match over the phone I think you need to go into the store.
  19. kifimoto
    kifimoto
    i've bought it from empire direct now so no worries!
    thanks for the advice! :smashin:
  20. bobbypunk
    bobbypunk
    just in case you're not aware, Most companies who offer service on out of guarantee products are now only doing it on stuff they sell. This means out of guarantee an internet sourced product will probably not seem like a good deal any more!!!
  21. kifimoto
    kifimoto
    i suppose i still get the one year manfacturer warranty?
