Receiver with DAB radio?
Discussion in 'AV Receivers & Amplifiers' started by Jamesy, Nov 23, 2004.
  1. Jamesy
    Jamesy
    Hi, im a complete newbie and looking to setup my 1st home cinema system, im specifically looking for a receiver with a DAB radio, im hoping to spend around £300-400 I would be very grateful for any suggestions u might have cheers!
  2. Flimber
    Flimber
    Sep 22, 2002
    13,681
    Yorkshire
    +4,477
    I haven't seen any but one should be along shortly. Only current way I know of is via Tag McLaren (maybe Arcam do one too) but only at multiples of your budget.
    Mike.
  3. Garrett
    Garrett
    Apr 21, 2001
    40,840
    2
    167
    The best thief you’ll never see.
    +6,903
    There isn’t one I have seen, it was originally reported the Sony 795 was going to have DAB by What Hi-Fi but it proved false the following month, I would have had one myself but went with the Denon 1905.
  4. recruit
    recruit
    I found with the DAB radio it can be quite fussy with reception and if you do not have a good quality signal it tends to drop out quite alot & then you will need a bigger arial which usually will have to be mounted outside!
    John
  5. Flimber
    Flimber
    Sep 22, 2002
    13,681
    Yorkshire
    +4,477
    Well, guess what ? There is an all-in-one A/V system for under £400 with DAB, it's a Samsung HT-DB770: no standalone reciever as yet though.
    HTH,
    Mike.
  6. Flimber
    Flimber
    Sep 22, 2002
    13,681
    Yorkshire
    +4,477
    Don't mention it.
