Receiver went 'BANG' !!!!
Discussion in 'AV Receivers & Amplifiers' started by Sienna, Jun 19, 2002.
  1. Sienna
    Sienna
    My STRDB 1070 went BANG last night after I had connected it all up, the supplier is very kindly sending me another one after a slight blag!
    As far as I can see there was no reason for this outburst but before I do it again can someone cast an eye over the following connects and tell me if I have done something drastically wrong that may have caused this to happen...
    DVD to Receiver via optical cable
    DVD to TV via Scart to TV AV1 Scart - RGB
    Video Scart to Receiver Video 1 audio plugs only
    Video to TV via Scart to TV AV2
    Connected all of this and when I plugged in the receiver it went bang....
    Faulty Receiver or Faulty connecting
    Thanks in advance
    Sienna :kisses: :confused:
  2. mjn
    mjn
    May 24, 2001
    22,731
    Herts, England
    +10,869
    Faulty receiver!!
    Even if your connections were wrong, u would either receive no sound / picture, or it would just cut-out.
    That said, if you plugged your mains supply into the speaker terminals, that may of done it!! :)
  3. Sienna
    Sienna
    Thanks MJN - I thought that was the case but was having a blond moment so thought best to check!
  4. highlanders
    highlanders
    Aug 24, 2000
    840
    Manchester, England
    +58
    Also check that the replacement is set to the proper voltage, mine as two settings 230v and 110v. Make sure that the speaker cables don't touch the melal of the case.
    James
  5. highlanders
    highlanders
    Aug 24, 2000
    840
    Manchester, England
    +58
    I mean matal :blush:
    James
  6. Sienna
    Sienna
    Hi James,
    Is there a switch on the back of the unit for this? - I could not find one when I looked but thanks I will be sure to check with the next one.
  7. highlanders
    highlanders
    Aug 24, 2000
    840
    Manchester, England
    +58
    Some have a switch or a screw head that you turn to the correct setting. It should say something like 230-240v near the socket on the amp if it's switchable. Don't worry if you don't see it that means the amp is already set to the correct voltage.
    James
  8. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I guess it was "metal" ...
    Anyhow, ensure to switch the AC voltage selector only when the unit is disconnected from the mains.
    The same applies to any impedance selector where applicable.
  9. Dom Rice
    Dom Rice
    Check the 4/8 ohm switch. I had a sony that went bang as I bi-wired the front speakers and had the switch set to the wrong position.
    The shop fixed the amp (when I thought it was a dodgy amp) then wired it up again only for the same thing to happen.
    Then I noticed the small warning notice. Didnt tell the shop this and they just replaced the amp.
    This note in the manual was towards the end and was very small.
  10. Sienna
    Sienna
    Thanks everyone, lots of good advice - I didn't realise setting up an amp was such a mine field!!!!
    I checked the faulty unit last night and it doesn't have a voltage selector switch so I am assuming the replacement will not have one either but will check.
    Thanks all - have a good day:kisses: ;)
