Receiver to pair with Nad M25 (input sensetivity/pre out voltage question)
Santho
I have an onkyo tx-nr717 which im looking to replace soon, which leads me to my question.
The power amp im using is the nad m25 which has a input sensitivity of
1250 +\- 50mV.
Im fairly new to this and my knowledge on things like this is minimal, but i’ve read that you’d want your receiver pre out voltage to be equal to or higher than the sensitivity on your pre amp to get your amplifier to put out the maximum power….?
My budget for the new receiver would be around 2000$ or so, i’ve looked at both the Denon AVC-X4700H and the Nad T758 v3i but im not finding any specs on pre out voltage.
does any one know the rated pre out voltage on these receivers i’ve mentioned..? or maybe sugestions for other recievers? Is this even something i need to worry about.. 😅?
rccarguy2
You'll be fine with that Denon it is about 1.4v preout with internal amps on, and goes past that easily past 1.6 and 1.8v with all channel pre amp mode
rccarguy2
And as and nad avr
Santho
And as and nad avr
Thanks for such quick response.. 😁 Reading the review of the nad it looks like the denon is the better choice.. shame because i kinda wanted to go for a nad receiver, as my power amp also is nad…
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
