Moonwalker2006
Established Member
I bought a LG NB3530 Soundbar and i want to use it with my Yamaha RX-V1700. I checked the manual and i did everything that i thought would be the logical thing to do, but nothing made a change. I am officially completely stuck. I'll explain how i have it set up.
- I have a Optoma projector, Yamaha receiver, Xbox 360, PS3, Wii U and LG Soundbar.
- One HDMI cable goes from the receiver's HDMI out to the projector. In the receiver's HDMI 1 (DVD) i have Xbox 360 and in HDMI 2 (CBL/SAT) goes either PS3 or Wii U. I only need to turn the input wheel of the receiver to DVD and i'll see the Xbox 360 screen on my wall, projected by the projector. I love this setup, cause it let's me easily switch between the consoles. I used to use a headphones and it would be easy as hell. But now with the soundbar....
-One optical cable from the soundbar;s HDMI In goes to the receiver's Optical Out and i choose CD. While video source naturally works at this point, audio does not.
- I check the manual and i decide to into the receiver's manual menu and into I/O assign. HDMI In is DVD and Optical Out is CD, where i got my soundbar's optical plugged into. I also tried using the remote of the receiver and using audio select, putting input to DVD and output to CD. But still nothing.
I simply want to keep this setup with the receiver and consoles and have the soundbar working for the consoles via optical. It's probably something small but i am completely stuck here. Any advice would be greatly appreciated.
If this simply is not possible, i'll have to switch optical cable from Xbox 360 to PS3 and Wii U each time i want to play one of them. Not the end of the world, but i was told it can definitely work with the receiver.
