Hello all,
My current setup is as follows:
2xB&W 683 towers
2xB&W 686 bookshelf rears
1xHTM61 S2 center
1xMonolith 15" sub
This is on a x2400h
This is placed in a living room, and not a dedicated audio room. (getting a second sub isn't an option)
I'm planning to upgrade to a 5.1.2 system soon, and may down the line get a 7.1.2 system going.
I would like to upgrade my receiver to fit future needs so mine needs an upgrades something that will last me quite a few years.
My usage is 80% movies and 20% music
My budget is between 1500-2000€, while I could spend 2000, it would have to be somewhat justified.
This presents me with several options:
On the other side of things I've been recommended to go a different route and look at a dirac receiver such as the NAD t758 v3i or the NAD t778 (which is well above my price range).
I could afford the NAD T58 v3i, but I'm not sure about replacing a 7.1 receiver with another 7.1 receiver, the T778 does look good, but at +3000€ that's very steep, and well above my current budget, and at that price I could get an anthem mrx 740.
I'm unaware of how other brands like Onkyo or Pioneer are doing these days.
Any advice or suggestions here would be appreciated, currently I believe that the X3700h is the "best value" option and should fit my needs quite well.
2xB&W 683 towers
1xHTM61 S2 center
1xMonolith 15" sub
This is on a x2400h
- Denon X3700h or Marantz SR6015 for 1100€/1300€
- Denon X4700h or Marantz SR7017 for 1600€/1900€
