Receiver or speakers at fault ?
Discussion in 'AV Receivers & Amplifiers' started by la gran siete, Sep 9, 2017.
  1. la gran siete
    la gran siete
    Oct 5, 2003
    25,276
    West Sussex
    +1,984
    I have a rather old pair of Kef Q55 a Kef Q85c and a pair of small Kef surround sound ( I forget which ones but they are dated) and a Yamaha RX-V1065 amp.The problem is that the sound I get particularly from the centre speaker, is just plain dull and I can barely hear the dialogue as it just sounds muddled, in fact, my LG Oled's own in-built speaker sounds better and brighter. I can also get better sound from Pure direct mode but that defeats the object of 5.1.
    I recently bought a Q acoustics 3090c centre speaker but that did not improve things so I kind of think may be the amp is faulty in some way so I am now looking to replace that and the front left right speakers (again Q acoustics)..Any suggestions? I am looking in terms of a Denon AVRX3300 as the price is agreeable to me but my main priority is to get that left/right/centre combination right.Thanks
  2. xmb
    xmb
    Sep 29, 2004
    1,261
    North Yorkshire
    +205
    Reset the Yamaha to factory defaults and run the setup again. (You could try listening after the factory reset before running YAPO.)
  3. Rodders53
    Rodders53
    Dec 8, 2007
    5,296
    Bedford
    +961
    Or even consider removing the dynamic room equalisation applied to the speakers. (The one that does what used to be called 'loudness' on hifi and radios: compensation for the ear's frequency response at lower volume settings).
    My Onkyo sounds much nicer, to me and swmbo, without it on.
    Not sure what Yamaha call it.
  4. southleft
    southleft
    Aug 5, 2015
    25
    3
    earth
    +22
    Yes, the old "Loudness" setting progressively boosts lowest bass octaves and highest treble octaves as you reduce the volume setting from maximum down to lower levels. The idea is to compensate for humans' reduced ability to hear those frequencies at quieter levels. Our ears remain sensitive to middle pitch sounds. So, Loudness or Dynamic EQ may produce a pleasing result when listening to music at low-ish volume, but it's definitely NOT a good thing if you're trying to make voices/dialog. By the way, those frequency curves are based on Fletcher & Munson's research on hearing way back in the 20th century!
  5. dante01
    dante01
    Mar 5, 2009
    46,552
    +11,216
    Try using a different PEQ setting or try bypassing PEQ altogether.
  6. la gran siete
    la gran siete
    Oct 5, 2003
    25,276
    West Sussex
    +1,984
    That may well solve the issue for me as I have it on the MAX setting.Many thanks for that.
    I just realised that I hadn't run the YPAO correctly although I had the microphone pointing directly at the ceiling I sited it on the back cushion of my sofa thinking that is where my head rests.Yamaha recommends the use of a tripod
  7. ian4949
    ian4949
    Apr 28, 2015
    37
    sy
    +10
    When running the YAPO use about 8 spots across the area where your seated . A tripod would be best but if you don't have one place the Mic in a spot it won't move . Run the YAPO . I've done my dennon a few times then changed cross overs manually. Cheers .
  8. dante01
    dante01
    Mar 5, 2009
    46,552
    +11,216
  9. la gran siete
    la gran siete
    Oct 5, 2003
    25,276
    West Sussex
    +1,984
    I shall be ordering a tripod and will follow the suggestions .For now, I used a stool but I see that is not ideal either. At least it saves me forking out on a new amp,although I suspect I shall replace the lt /rt speakers
    Many thanks
  10. la gran siete
    la gran siete
    Oct 5, 2003
    25,276
    West Sussex
    +1,984
    Ok, so doing that presumably averages out the sound across the area covered by those eight spots?
  11. la gran siete
    la gran siete
    Oct 5, 2003
    25,276
    West Sussex
    +1,984
    I see from one of your posts you recommend the use of a boom Mic stand .Presumably one can attach appropriate accessories to the end of it to produce a surface fit for the mic?
    seems to me I need something like thishttps://www.amazon.co.uk/s/ref=nb_sb_noss?url=search-alias%3Dmi&field-keywords=On+Stage+CM01+Video+Camera%2FDigital+Recorder+Adapter
    fitted onto something like this https://www.amazon.co.uk/AmazonBasi...TF8&qid=1505126288&sr=1-5&keywords=boom+stand
  12. dante01
    dante01
    Mar 5, 2009
    46,552
    +11,216
    I've a boon mic stand and use a mic to camera mount adaptor to fascilitate mounting the calibration mic.
    [​IMG]
    The adaptor is available here:
    1/4
    It should fit most mic stands, but some stands may require a 3/8" to 5/8" screw thread adaptor?
  13. la gran siete
    la gran siete
    Oct 5, 2003
    25,276
    West Sussex
    +1,984
  14. la gran siete
    la gran siete
    Oct 5, 2003
    25,276
    West Sussex
    +1,984
    i have now bought those two items so hopefully, they will do the trick.Many thanks once again
