Receiver Muting at 80%?
stereosal
hi,and merry christmas, i have a realistic sta-2700 receiver and when using "muting" it only mutes at about 80% anyone know if this is normal or should i be looking for something? all caps look fine, any help would be appreciated.
jason1wood
I have a Yamaha receiver and there's an option in the menus to control and set the muting facility, have you checked your menu, muting might be set at 80%?
Merry Christmas.
stereosal
thanks for your advice, it's a pretty old receiver maybe 15-20 years old it does not have a digital menu. i found it on the sidewalk with the power plug cut off (like new condition), after some repairs i found the muting to be the only thing not to work properly.
Podcast: Large Screen HDR TV or Projector For Home Cinema + Best of the Month
