Receiver for stereo
Discussion in 'AV Receivers & Amplifiers' started by Spaced, Jun 22, 2004.
  1. Spaced
    Spaced
    Hi all, I've been perusing through the threads on here, but haven't really found anything that quite answers my question.
    Basically, I'm looking to buy a receiver and speakers for stereo (music) playback primarily (sourced from either a Squeezebox (optical/SPDIF) or optical out of PC. In the future I'd like to be able to expand this out to connect to DVD and then 5.1, but not quite yet.
    Music wise, I listen to a bit of everything, so good all round performance is a must.
    So, what would you recommend? I'm looking at spending around £300-400 max for both amp and speakers. I don't mind buying an older model, or even second hand.
    Cheers!
  2. Barend
    Barend
    Apr 12, 2004
    804
    +9
    Harman Kardon is the way to go, the black series is cheap now.
    Barend
  3. boab_is
    boab_is
    You can probably pick up a sony strdb790 for around £200 online. leaves you a fair amount for speakers. if music is your thing make sure you get a decent set of bookshelf/floorstanders for the fronts. sat/subs dont do music properly(big midrange gap).
    hope this helps
  4. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Also look at Marantz and Nad. There amps are good for music and also second hand Arcam's.
  5. Spaced
    Spaced
    Cheers all, I'll look into those.
  6. bluesfan
    bluesfan
    Feb 10, 2004
    303
    16
    Yorkshire
    HK got very good on the fm pickup plus the sound of course.
