Receiver for low volume listening
Discussion in 'AV Receivers & Amplifiers' started by Blindman, May 15, 2005.
  1. Blindman
    Blindman
    Dec 12, 2004
    108
    Hi, we have been told that a higher power amp (Arcam AVR300) would be better for lower volume listening than a less powerful one (Denon 3805). By power, I mean actual watts per channel, not just manufacturers quoted figures.
    Is this true, or a sales pitch?
    Will the effect be reduced by using low impedance speakers? - we will be using Quad L series, rated at 6 ohms
    We did try demoing this but the room size was very different from ours, so it was hard to ccompare this particular feature.
    Please help, :lease:
    Thanks.
  2. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    IMHO, the Arcam would be better than the Denon, but not because it is more powerful. I would argue that the "quality" of the amplification is more important.
    Quads are one of my favs for listening at low volumes.
  3. Garfield
    Garfield
    Essentially the dealer is telling the truth, more powerfull amps generally get better components, don't make the mistake of equating watts with volume.
    Don't forget about the speakers in your system, if you want to hear clarity and depth at low volumes the lower the volume the better your speakers need to be.
  4. Blindman
    Blindman
    Dec 12, 2004
    108
    Thanks guys! :thumbsup: - we've gone for the Arcam!
