Receiver Choice?
Discussion in 'AV Receivers & Amplifiers' started by moss6, Jan 13, 2003.
  1. moss6
    moss6
    I'm narrowing down choices on a new av receiver and am debating between three Yamahas the RX-V1 the RX-V3200 and the Rx-V3300. I'll be using the preouts for the mains two drive some 4ohm speakers thru a Yamaha M-85 amp for listening to music from CDs, LPs or radio. The receiver will be used otherwise as a surround sound system for video sources.
    I'd like to have some input on what is considered to be the best of the three as I haven't had much luck in finding any comparing reviews.
    Thanks,
    Randy
