Receiver and Subwoofer Connection
Discussion in 'Cables & Switches' started by whattodo, Sep 16, 2005.
  1. whattodo
    whattodo
    Aug 9, 2005
    56
    9
    Ankara
    I plan to buy Arcam AVR300 or Denon 3805 receiver. If I connect a receiver with a subwoofer with seperate audio cables instead of one subwoofer cable, which cable should I use? Is a standart speaker cable for instance 12-Gauge cable enough?
    And also I am lost in cable definitions. :rolleyes:
    What are the differences between these cables: the optical cable with or without Toslink, digital coaxial, glass digital optical, optical fiber cable with or without Toslink?
  2. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,551
    The Fylde Coast
    +12,872
    Subwoofer cable carries LF signals, including the 50Hz frequency which is present in all our electric supplies. As a result subwoofer signals are susceptible to noise. Mark Grant cables use a special double screened Canare cable designed for this type of application. If you search for a thread by Mylo he describes different approaches to DIY cable. Some use CT100 "sat cable", Mylo used double screend microphone cable. I just made a 15m sub cable today from this latter cable. 80p per metre. It's more flexible cf. the CT100.
