Question Receiver advice
Eddiebliss
Hello, long time reader, first time poster.
I have a modest room for my home theater set up, and am looking for advice for a receiver...looking for something inexpensive but good quality to power a 5.1 setup...any advice? Thanks,
Ed
dante01
What kind of budget do you have. What are the dimensions of your room. What other devices and TV do you intend to use this receiver in conjunction with? What speakers do you have or intend powering using tis receiver?
Eddiebliss
Looking under $500. Room dimensions are about 13 x 20 ft. I have an Epson projector, and am planning to have an Xbox, Apple Tv, and maybe a roku connected. Will probably get a set of polk speakers
dante01
It is hard to suggest a receiver for you if you are in the USA? This board and its membership is based in the UK so the price we pay for some items may duffer to the price being charged where you are. What I can do is suggest some candidates that are likely to be priced in accordance with your budget. I'd maybe suggest one of the following:
Denon AVRX1400
Sony STRDN1080
Yamaha RXV583
