Reccomend me a Freeview Box for under £100
Discussion in 'Freeview & YouView' started by 9761, Jun 24, 2005.
  1. 9761
    9761
    May 16, 2005
    536
    Hi, :lease:
    Want a nice freeview box to go in my room and to use it with my Toshiba 32ZP48P TV.
    It needs to have a good picture and sound, Optical port on the back and must be horizontal shape casing (something like the sony but horizontaly).
    Any ideas?
    Oh and if I found a Freeview box that can output component would I get a better picture than a RGB scart picture?
  2. Maff et1
    Maff et1
    The sony has a removable stand, it can lie flat fine.
    Component doesn't give an improvement unless it's prog scan and the de-interlacer in the STB is better than the display.
    AFAIK there are no Freeview boxes with prog scan, a few do have component (my Topfield 5800 PVR does for one), but unless the signal handling for component is better than RGB in your TV it won't make a difference.
  3. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
  4. 9761
    9761
    May 16, 2005
    536
    That looks very nice, can anyone tell me what the Pace twin STB picture quality is like and is it as fast as the sony?
    Oh and what does the (puma) part mean :confused: ?
  5. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    The Pace Twin is/was the first Freeview stb with a hard drive. It has an excellent epg and menu layout (still perhaps the best). It has a reputation for being unreliable; although mine is now totally reliable.(I have had one for over two years). Picture quality is fine. Do not know how its speed compares with Sony or why it is sometimes called the PUMA. I do not think anyone does. It records about 10 hours of TV which is considerably less than recent PVR's but infinitelly more than stb's that do not have a hard disk at all. :)
    Richard
  6. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Usability is first class, quality is almost as good as my IDTV tuner - probably because it is not using Scart but is soldered to the main chassis board!
    Reliability is quite good.
    Connectivity is excellent.
    It was £350 2 years ago
  7. 9761
    9761
    May 16, 2005
    536
    Hmmm does look nice, is that a top up TV slot on it?
  8. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    PACE have "nicknames" for their products, PUMA was the one chosen for a class of STB's with digital tuner/s with or without hard drive recording. PUMA2 I believe was for dual tuner products with an integrated hard drive while the baseline PUMA just had twin digital tuners.
  9. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Not titsup - but that will go bust eventually
  10. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    I never heard of that. did they actually make a model with twin tuners but no hard drive? The Twin (which has two tuners; obviously; and a hard drive) is somtimes reffered to as the Puma but I never heard it reffered to as the Puma2.
  11. 9761
    9761
    May 16, 2005
    536
    Does anyone know where the cheapest place to get this from, cheapest ive seen is £115 inc del is that good?
  12. BigJonnyBravo
    BigJonnyBravo
    May 29, 2005
    40
    Worcester
    Not sure on the prices now but I paid £180 18 months ago, so it sounds reasonable.
    I'll back up what has been said about PQ.... excellent.
    Mine has crashed probably about half a dozen times over those 18 months.... simple remedy... pull out the plug and turn on again. Worked every time. However this has got better as time has gone on... whether this is as the updates have remedied things as time has passed I'm not sure.
    The hard disk is small by todays standards but I don't record too much and never to keep to its fine by me. I guess it may be an issue if u do record stuff and it takes u a while to get round to watching it.
  13. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    I recall hearing the name when the exisitence of the DTT unit was just a rumour, not long after SKY+ had been released actually.
    I don't think PACE ever released a twin tuner Freeview box but they do operate in global markets so it's possible that variants of the basic design were sold to other countries and the PUMA name just migrated to the only box they sold in the UK.
  14. 9761
    9761
    May 16, 2005
    536
    Do you think I will notice any picture and sound improvement than my Goodmans GDB3 STB?
    Its currently connected into Scart socket 1 on my TV (Toshiba 32ZP48P, RGB socket 1) via QED P2110 SQART cable.
  15. BigJonnyBravo
    BigJonnyBravo
    May 29, 2005
    40
    Worcester
    hmmmm...... not sure, never having seen the Goodmans GDB3 STB!
    I reckon that if you'll find the hard disk useful it may be worth it, but if not then I reckon probably not... but as previously said thats not based on any real evidence!
  16. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    The Twin is a joy to use however - the operating system is very well designed
  17. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    OH and the ability to do recordings IDENTICAL in quality to live broadcasts is brilliant
  18. 9761
    9761
    May 16, 2005
    536
    Well Thanks guys,
    I will be looking to order one of these this week sometime.
  19. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,423
    Somewhere in South Yorkshire
    +5,823
    I'm sorry to pour cold water on this, but I thought I'd better offer an alternative experience. First up - my Freeview signal is of high quality; I'm pretty well line of sight to Emley Moor about 25 miles away. Other boxes give me 100% glitch free reception.
    BUT: The twin creates it's own glitches. Despite having partly dismantled it and improved the internal earthing, when both tuners are tuned to the same mux, they will interfere with one another and massive increases in the bit error rate are the result.
    I'd echo the comments on the User Interface - it is good. And when it's behaving, the received and recorded PQ is excellent. But, I'd say - you simply can't rely on it.
    A recording may be perfect. Most are.
    Or - it may have massive glitches in it (see above)
    Or - worse still - whilst it was recording, it may well have hung, meaning it has continued to record, filling up the HDD. The only way to recover is to disconnect power. This act renders the said recording unwatchable, so the only thing you can do is delete it.
    Overall - unreliable junk.
  20. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    I'd recomment the Sony, it is designed to be vertical or horizontal. Its a well made box, nice menus, fast interactive, fast channel changing and Sony do updates to the software until quite a few other well known brands.
  21. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    I tend to get one lockup a year, except for May 04 software which just did not work
    If you get a reliable one they are great - most of them are!
  22. 9761
    9761
    May 16, 2005
    536
    Oh dear, all these problems are tempting me not to go for one now :(
    But it just looks soo cool and that I just may have to order one :p
  23. LV426
    LV426
    Jul 14, 2000
    13,423
    +5,823
    If you can stretch your budget, you may find a Dixons or Currys with the original Humax 40gb box on sale. They are reduced as Humax have reworked it with a bigger HDD. So the old 40gb ones are about GBP120 IIRC. Now these are very basic, single tuner, but are nigh on 100% reliable.
  24. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    I am not reccommending you to get a Pace Twin but at this price point these seem to be the options.
    1 a single tuner STB. Admittedly at this price you can get the best but at the end of the day how much can an ordinary STB do whatever it costs.
    2 A Pace Twin; With 2 tuners and an admittedly very small hard disk. It is long in the tooth but most of them are not complete junk; mine has perhaps lost a dozen recordings (max) in the last 2+ years. Not perfect but compared with something that does not record at all; its not a difficult decision IMO. You may get a dodgy one of course but that applies to any piece of kit.
    Increasing the budget would complicate things a lot of course. With your criteria (a freeview box under £100) the twin has got to be a contender if they are going for that kind of money.
    Richard
  25. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    As a Twin owner for over 2 years I can state what the reliability is like.
    I have had a couple of power off lock ups but not recently May 04 was rubbish, October 03 and Late 04 were both reliable.
    How to increase reliability
    Make sure it has free air flow.
    Use a clean power supply (even one of those 6 way blocks with filters in)
    Allow the unit to do what it wants - ie don't go press press press - do press - function - press - function. Mad button pressing can confuse it.
    Do not leave it recording with tuner 1 on ITV/C4 ect or SDN multiplexes - both are dodgy with EPG data which the Twin uses when recording. I find BBC1, 2, News24 are all good channels to leave it on.
    Most lockups are due to my wife turning it off when on ITV rather than BBC
    The usability of the Twin is the best of the PVRs it is very user friendly and well featured.
    I will be buying one of these £100 recorders when they are relisted.
  26. 9761
    9761
    May 16, 2005
    536
    one thing I need to ask before I order one of these,
    How fast is the menu etc? almost instant would you say?
  27. 9761
    9761
    May 16, 2005
    536
    Bump ^^^^
    Oh I will be using a IXOS 0.75m RGB Only Scart and a optical cable for this, is that the best I can get from this or is there any better?
    Thanks!
  28. LV426
    LV426
    Jul 14, 2000
    13,423
    +5,823
    When it's behaving itself, the Pace Twin has an excellent and responsive UI and menu. The only thing that's laboriously slow is the EPG, which isn't cached or downloaded overnight, etc. When you first select it (following a switch on) it can take upwards of 10 minutes to fully populate. Turn it off, and you've another long wait the next time.
    When it's behaving itself.............. (which in my experience, is most, but nowhere near ALL of the time).
    Contrary to what others have said, in my experience you simply cannot rely on it to always successfully make timed recordings.
  29. 9761
    9761
    May 16, 2005
    536
    I hardly ever use the EPG tbh. I only use the Program + & - to switch channels and I probably hardly ever use the recording timer.
    What would you say about the cable issue would a Top quality RGB only scart and optical out be good or is there any other better ways of connecting my TV (Toshiba 32ZP48P) to the Pace twin?
    Thanks!
  30. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Decent RGB Scart and digital optical sounds fine
