Rebranded Grundig LCD no longer an option!
Discussion in 'LCD & LED LCD TVs' started by Rusty, Jun 18, 2003.
  1. Rusty
    Rusty
    Just received this:
    Sincere apologies, but I have this evening received the below communication from Ronin, indicating that the EZV17 will not be available through resellers in the UK.
    The closest model that I can currently offer is as follows:
    Relisys RTL1720S 17" TFT Monitor/TV - £399.15 + VAT = £469.00
    17" Widescreen PC Monitor with D-Sub Input
    Built in TV Tuner, S-Video, AV-In, Audio-In, Digital Interface
    Remote Control, Picture in Picture, Wall Mountable
    Monitor Resolution 1280 X 768, Response time 16ms
    Contrast Ration 400:1, Brightness 400cd/m2
    Sorry for any inconvience, you will be deleted from our addresses database and will not receive any further communication without requesting it.
    Dave Cooke
    DCCS Limited
    davec@dccs.co.uk
    http://www.dccs.co.uk
    Tel 01823 412343
    Fax 01823 413993
    Mob 07900 570369
    Dave.
    HI there I am MD of GNR group companies of which Ronin is one. We are in
    deeply embarrassing situation. Typically 90 -99% of our business is
    making for Global Brands.
    This product <EZV17> has been sold exclusively to a big German OEM for their TV
    business and is available only from ****** in UK. This is confidential
    information as I am sure you will understand but I have to share it
    with you.
    I do not know how to apologise enough but we have lost out at the
    expense of OEM customer. I deeply apologise
    Very Best Regards,
    Dave Stevinson
    Dave Stevinson
    Managing Director
    GNR Corporation Limited
    http://www.gnrintl.com
    Mobile +44 (0)7976 411467
    DDI: 0870 1280 881
    Fax: 0870 1280 878
  2. gunrock
    gunrock
    Apr 3, 2003
    132
    The Burbs, London, UK
    That's interesting because I've been looking at the Relisys in the last few days.
    I have a PDF datasheet for it if anyone should want it, it's about 340k. If the response time really is 16ms then I think this could be very good value for money. With Component-in and 16ms refresh this could a great console gaming monitor as well as a PC monitor and TV.
    Slightly worryingly, the Relisys sites have absolutely no information on this screen. Does anyone have a manual (so I can examine the back panel) or seen one in action?
    Steve
  3. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    Got the pdf and a couple of shots. The spec has changed slightly though, the inputs are going to be on the tuner board part of the unit (i.e. the vertical bit as opposed to the horizontal bit they're already on).
    The photos will be on our site as soon as the web designer gets round to it.
    I'll get to see one myself in a fortnight which I think is when the main bulk of stock will be here to send out. Will post comments as soon as....
  4. gunrock
    gunrock
    Apr 3, 2003
    132
    Thanks Liam. I wonder why the inputs are being moved. Hopefully it's only an internal pcb redesign rather than an exercise to reduce cost at the expense of quality. Tuners often output a lot of heat (and sometimes interference if the shielding is poor) but hopefully, this won't affect the component and PC-vga inputs.
    Steve
  5. Dutch
    Dutch
    Dec 5, 2002
    2,594
    3
    North Yorkshire
    +281
    Hi Liam,
    Do you know what the "digital interface" is mentioned in the first post? Would it be DVI?
    Steve
