Rears: Mission 700's or 77DS's
Discussion in 'Home Cinema Speakers' started by joust, Feb 5, 2003.
  1. joust
    joust
    Sep 4, 2002
    944
    28
    Basildon, Essex
    +55
    I'm currently using mission 700's as my rears. I recently purchased a set of 77ds's, to add one of these for the 6th channel. However, after reading other experiences, I don't think that I will ever install the 6th channel. So I now have a choice of what to use for rears (and then sell the other set). Question is, what's the recommendations?
    Joust
  2. greenthumb
    greenthumb
    Err.. keep the ones that sound better to you:lesson:
    Seriously trhough, I have the 77's along with many other members of the forum and are very happy with the sound from them.
  3. j4sonk
    j4sonk
    if your going to use them,put them level on side walls above ear height as surround.and use a 700 as surround back.this will be a much better solution.i have had no bad experience's with 6.1?
