Rear USB Ports.....
Discussion in 'Nintendo Wii-U & 3DS' started by TwoJs, Dec 28, 2006.
  1. TwoJs
    TwoJs
    Jul 18, 2006
    11,590
    Somerset
    +3,867
    so what is going to be brought out to use these for then, will it pick up my usb data stick to transfer pics/music or anything like that ?
  2. TwoJs
    TwoJs
    Jul 18, 2006
    11,590
    Somerset
    +3,867
    bump :)
  3. Mafro
    Mafro
    Dec 5, 2006
    369
    +15
    Apparently you can charge your ipod using it.
  4. TwoJs
    TwoJs
    Jul 18, 2006
    11,590
    Somerset
    +3,867
    really ?! sounds good, can you plug in a usb keyboard to use opera browser easier tho that would be cool
  5. PlexShaw
    PlexShaw
    Oct 12, 2005
    2,811
    London
    +538
    Well, the USB to LAN adapter will be one use for the ports (for those who don't have a wireless setup in their home).
  6. candi
    candi
    Dec 7, 2006
    307
    +56
    No it doesn't work. Plugging anything that Nintendo doesn't recommend voids the warranty, that includes charging your ipod.
    The only use Nintendo has said they will be for so far is the LAN adaptor out next month.
  7. SHPanda
    SHPanda
    Dec 9, 2006
    152
    +6
    :rotfl: Voids the warranty, I think that's far from true.
  8. candi
    candi
    Dec 7, 2006
    307
    +56
    It states so in the manual you get with the Wii.... :rolleyes:
  9. popester_uk
    popester_uk
    Dec 10, 2002
    316
    Brighton, East Sussex
    +9
    It has been mentioned before that plugging a non-Nintendo USB device in will void a warranty (would be an interesting test case) but I think the bit in the manual may just be a catch all to save Nintendo's bottom should the worst happen.
    Lets face it, it's a serial port at the end of the day, with a bit of power thrown in for good measure.
  10. Mafro
    Mafro
    Dec 5, 2006
    369
    +15
    How the hell would they know you've plugged something in there?
  11. shagaboopon
    shagaboopon
    Nov 22, 2006
    3,279
    North Yorkshire
    +367
    Possibly they have some safety circuiy that blows if you put a faulty device in. They could then ask you to send the faulty device too. Perhaps the drivers required to run the usb device identify it has been a none nintendo product. Whatever the theory I'd be astounded if Nintendo ever voided someones warranty over it.
  12. SHPanda
    SHPanda
    Dec 9, 2006
    152
    +6
    Well I tried a keyboard on my first Wii before it broke (dreaded error code) and I've since sent it off to Nintendo and received a new one...
  13. norealplan
    norealplan
    Mar 26, 2005
    5,142
    Backpacking around the world
    +733
    One of my mates had a faulty gamecube console a few years back. He sent it off to be repaired, but happened to send it off with a joytech pad and not the official one. What did nintendo do? Sent it straight back saying he had voided the warranty by using a third party product. So yes nintendo would probably never be able to tell if you put your ipod in the back of it, but i would definitely suggest not to mention it to them!
  14. Abyssandrew
    Abyssandrew
    Aug 30, 2005
    141
    +4
    If it was by any means possible to damage a Wii by plugging a functioning USB device into it, then the connection type would be non-standard, the same as pretty much every other connection on the Wii. The truth of it is though, there is no way a working USB device is going to damage a Wii, and there is no way Nintendo are ever going to know you used one.
    An Ipod will charge using the USB as it is simply taking the power from the 5v line of the USB connection, this will work for any usb connection regardless of what it is (360, Wii, Mac, usb cigarette charger etc).
  15. TwoJs
    TwoJs
    Jul 18, 2006
    11,590
    Somerset
    +3,867
    so in theory I can charge my Tom Tom like I do on my imac at the moment ?
  16. kez
    kez
    Jan 18, 2002
    8,355
    Leeds, West Yorkshire
    +1,348
    probably. give it a try? ;)
  17. Conn
    Conn
    Jan 2, 2005
    2,075
    +170
    I plugged the USB lava lamp I got for Christmas in to it, works a treat and looks kinda cool :D if your in to that sort of thing.
    Think I'll add my DS charger to the other one, keeps everything in one place...or a splitter so I can get the Micro in as well ;)
  18. paulwillhappy
    paulwillhappy
    Nov 22, 2006
    13
    What about one of those usb rocket launchers? :oops:
