Rear Surrounds with Denon 3802
Discussion in 'Home Cinema Speakers' started by petrolhead, Apr 7, 2002.
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,863
    87
    Newcastle
    +123
    Having decided to buy a Denon 3802 I now have to also buy some rear surround speaker.
    I currently use Monitor Audio Baby Monitors with a Paradigm PDR10.
    What should I buy for the rears. I had thought about some Bi/Di Poles for the sides and puting the Monotors at the rear.
    What are you guys using, setup wise, for DD 7.1?
    Peter
  2. Jase
    Jase
    Mar 16, 2001
    10,723
    United Kingdom
    +2,498
    Got dipoles at the sides and monopoles as Surround Backs.
    Works well for my setup. You should also place the Surround Backs as close together as possible. The thoughts on Surround Back placement have now changed, THX Ultra 2 specs now say this is the best setup (I have to agree!!)
