Rear Speakers
Chewbacca
I need a little help
I am looking for a good pair of rear speakers my old ones are past they best but I am unsure what to buy.
Dipole are out of the question because I have not the space to postion them on the side walls.
My front speakers are B&W 601 any ideas would be of great benifit please.
My price range is £500.:)
MuFu
How about the B&W 600s? They really are substantially smaller than the 601s and can be wall-mounted.
If you have £500 and 6.1/7.1 capability, maybe get four. :D
MuFu.
Ridcully
Or perhaps do what I am doing and move the 601s to the back and buy some new fronts 603s
see 'what size B&W speakers' thread for more
Ridcully
603s are £599. As with most B&W speakers they don't appear to get discounted or put in the slaes that often. Sevenoakes are offering £70 worth of cabling with them so that may be of use. I have been told but have no experience that the 604s are not a good speaker unless your room is absolutely massive
337GUS
Do you have a sub and what centre speaker are you using?
Gus
N
nathan_silly
B&W make a pair of matching tripoles. £400 new. You didn't say if the back wall is available.
They're made of plastic though....
Nathan
Chewbacca
Hello they
My centre speaker is a B&W CC6 and I have been using a Monitor Audio asw210 sub but at the moment I am using a REL Quake My room is quite small.
I do have room on My back wall for speakers.
Can you use tripole rears on the back wall?:)
Matt F
Nathan
Didn't realise B&W did tripoles - what model number are they?
Their website doesn't seem to mention any tripoles as part of the 600 S3 range.
Matt.
N
nathan_silly
I don't think they had a 6xx previx. If I remember (could be wrong on sizes) they had two x 2" midrange about 15-cm apart, and a 3" black woofer facing forwards.
They didn't have a tweeter though.
My local shop had a pair for £150- think new £400, I did have a 601 front and CC6 centre, but the build quality -all plastic- and lack of tweeter put me off.
I'm pretty sure they are THX.
Oh if the magazines read these forums- in the reviews they never said of the plastic build quality. I didn't know until I saw them.
Anyone here remember the model name?
N
nathan_silly
hmmm. they're dipoles. Thought the front facing driver was to make it a tripole. Oh well..
Chewbacca
Yeah looked at the Ds6 a couple of years ago but if my memory serves me right the dipole speaker arangement does not suit rear wall mounting.
Going to have a look at a pair of 603's next week end and go from their.
I will possible put My 601's on the back wall.
Just one thing though will My centre cc6 be ok with the 603's:cool:
N
nathan_silly
Can you convert dipoles to bipoles and vice versa? If all you need to do is reverse the phase on the back-firing side then could convert then DS6's to bipoles easily...
337GUS
Chewbacca
I would look into getting the LCR600 centre as it is a better match for the 603's.
I am looking for a pair of DS6's, if anyone knows where I could get a pair would appreciate it - new or 2nd hand. Tried www.ex-dem.co.uk etc but the ones listed are gone.
Gus
Similar threads
Trending threads
