rear speakers...
Discussion in 'Home Cinema Speakers' started by andypandy, Dec 19, 2006.
  1. andypandy
    andypandy
    Feb 6, 2002
    598
    Surrey, UK
    +10
    Can anyone suggest a pair of high quality 'small' rear surround speakers. The smaller the better. I want to place them near the top rear corner of our ceiling. I currently have floor standing ones that simply take too much space (you can see below I use the mission ones).
    I am after quality hi-fi ones that provide depth and a quality sound and can handle minimum of 50 watts each. My amp is the sony 45x5. Most of the ones I see in shops (comets, dixons, etc) basically sound crap. But I suppose you get what you pay for. £100 can buy a complete surround package of speakers.
    Price - well, I suppose upto about £100.
    I want to place the speakers out the way, but will direct them downwards towards the central viewing position.
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,480
    2
    +1,367
  3. andypandy
    andypandy
    Feb 6, 2002
    598
    Surrey, UK
    +10
    thanks for that. I see there is a similar spec Wharfedale set listed above the mission which also look interesting. The problem is they are both £150 approx - which is more than half I wanted to pay.
    Both of those bio-piolar ones look awfully similar to the ones richer sounds use (?) to sell quite cheap. I might just check them too.
  4. andypandy
    andypandy
    Feb 6, 2002
    598
    Surrey, UK
    +10
    another idea I had was to place the rear speakers on the side (top) of our open through lounge partitition wall. So effectively they were positioned behind the viewers ears and then they would not have the sound bouncing off any wall. By positioning the speakers IN the front room - top rear corner one of the biopoar speakers would be pointing to a wall.
    It's all a bit difficult explaining it without pictures !
  5. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Mine... Anthony Gallo Micro...:D
    OrbAudio makes them cheaper...:cool:
  6. Nonplused
    Nonplused
    Dec 10, 2006
    24
