Rear Speakers
Discussion in 'Home Cinema Speakers' started by aj, Jan 16, 2001.
  1. aj
    aj
    Hi all
    I am looking for some goog rear di / bi pole speakers.
    I fancied the Paradigm apd150s but my avc a10se will kill them.
    Not enough power handling ability.
    I anly want to spend 300 to 400 pounds (if that)
    Any ideas folks??
    AJ
  2. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    Try a pair of KEF 65DS dipoles - very nice speakers, they retail at £400 but you may be able to get them for nearer £300 from certain dealers. You could try Sound & Vision - although they haven't got the best reputation, I picked up a pair of KEF's THX TDM34DS dipoles from them for £550 when they retail at £699.
    Hope this helps.
    This is a local shop for local people - there's nothing for you here!
  3. Ars longa, vita brevis
    it won't kill them unless you turn the volume up too high.
    if you're still concerned, lower their level.
    Assumption is the mother of all errors
    member formerly known as hank hill, the Jesus H
    but he got bored of that so changed to some latin sh*t
    'which is nice'
  4. Ars longa, vita brevis
    what aboot b&w dipoles
    about 400 quid
    'which is nice'
