rear speaker woes....
Discussion in 'Home Cinema Speakers' started by johndoe1, Sep 30, 2004.
  1. johndoe1
    johndoe1
    Aug 25, 2004
    2,368
    48
    +46
    I currently have 3 m&k k7's for my lcr
    2 x k4's for my rear lr
    a k9 sub
    yammy 750se
    qed silver all round (banana plugs)
    I am going 6.1 - will a k5 be sufficient for the rear channel or do i need another k7?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    K5 will be fine as it is a tonal match for the K4
  3. johndoe1
    johndoe1
    Aug 25, 2004
    2,368
    48
    +46
    presumably a k15 would also be fine?
  4. Sniper
    Sniper
    Apr 27, 2004
    1,294
    +80
    just realized i've asked a similar question today!
    got same answer from IanJ too (very patient - thanks)
    I think the answer to that (K15 will be ok instead of K5) might be a no - different tweeter (brighter i think) might make it stand out a bit too much compared to the others! Oh - also consider that I might be totally wrong (heh!).
