Rear Speaker Recommendations
Discussion in 'Home Cinema Speakers' started by makum, Dec 11, 2004.
  1. makum
    makum
    Hi I'm buying a new amp which will require (I believe) 4 rears for the 7.1 effect. I have a set of mission 77ds at the moment do I:
    Try to find a second set of 77ds ?
    Buy four new ones ? If it is buy 4 new ones any recommendations.
    My amp budget is £1500-2000
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    get a set of m71i from richer sounds to use as the back rears and some speaker brackets.
  3. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    Do you think these would match my Monitor Audio BFX for the rear centre channel, or are they tonally very different, and would therefore sound poor.
  4. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    I have no idea but with the rest of your speakers I would stick to MA speakers. Its usually not so important about mixing speaker manufacturers with the rear speakers as they dont do so much work compared to the fronts.
