Rear Speaker Question
Discussion in 'AV Receivers & Amplifiers' started by Nobber, Feb 15, 2003.
  1. Nobber
    Nobber
    Nov 29, 2001
    317
    I have two small rear speakers which I'm about to replace, is it possible to connect them together to be used as a rear centre?
    thanks
    Nobber
  2. nhk
    nhk
    Dec 30, 2002
    82
    In a 6.1 system, with a 3802 amp, how does one wire the centre rear. Does this leave one of the 7 Denon amp units unused?
  3. Jase
    Jase
    Mar 16, 2001
    9,461
    South Coast
    +887
    Yes, the Surround Back Right channel is unused. Just connect the Surround Back Left channel and select the relevant speaker/s in the main SET UP menu.
  4. sounddog
    sounddog
    Dec 11, 2002
    3,371
    107
    Leicestershire, UK
    +461
    Please note I can't take any responsiblity for you trying this ... if things do go wrong then you're on your own sorry ...
    Yes you can do ... but wire them in series
    i.e.
    +ve amp to +ve spkr1
    -ve spkr1 to +ve spkr2
    -ve spkr2 to -ve amp
    This should make sure that not too high a load is placed on the amp. Try it ... you shouldn't damage your amp or anything, so for a piece of cable it would be worth trying.
    Victoria
  5. Nobber
    Nobber
    Nov 29, 2001
    317
    I've bottled out on that one now see new post
    re controlling two amps
