Rear speaker positions
Discussion in 'Home Cinema Speakers' started by Irf, Jan 6, 2003.
  1. Irf
    Irf
    Jan 2, 2003
    191
    London, UK
    Should I mount a pair of Mission m7ds rears on the back wall (behind my sofa), or on the side walls? Are these speakers really bipoles?
    Thanks,
    Irf.
  2. sparkymarky
    sparkymarky
    Dec 12, 2002
    1,071
    48
    cornwall
    +32
    i have the same dilema!- thread 'help......room setup for rear speakers'
  3. Burt
    Burt
    I have the M7DS' and initially mounted them on the rear walls, I then moved them to the sides as recommended on the Dolby site and found the sound field to be greatly improved.
    Basically, if your seating is close to the rear wall then mount the speakers on the sides facing each other - if you can put some distance between your seating and the rear wall, then mounitng the speakers on the rear wall is probably the preferred option.
    Yes these are bipole speakers
  4. Irf
    Irf
    Jan 2, 2003
    191
    London, UK
    Thanks Burt - side walls it is then..... but they may then have to be quite high on the wall, like above a door..... :(
    Irf.
  5. sparkymarky
    sparkymarky
    Dec 12, 2002
    1,071
    48
    cornwall
    +32
    burt can you take a look at the pic of my room and confirm if you have the speakers in position 1?
    the thread is in 'avhardware>general hardware> help! ...room setup for rear speakers'
    (sos-dont know how to provide links to threads)
  6. Burt
    Burt
    Irf, The ideal height is about 5 ft, however if you need to go higher, you should consider mounting the M7DS' upside down (they are disigned to allow this in order to direct the sound downward). Experiment until you achieve sound you are happy with.
  7. Godfather
    Godfather
    Feb 12, 2001
    2,223
    63
    Edinburgh
    +224
    I've got 2 pairs of these and have mounted them upside down against the ceiling - a pair on the side walls and the other on the rear wall. They look and sound great though I'm probably too close to the rear wall (<1m).
