Rear speaker positioning
Discussion in 'Home Cinema Speakers' started by craiglad, Jul 30, 2002.
  1. craiglad
    craiglad
    I'll be setting up my rears tomorrow night and was wondering where i would best position them. My sofa is right on the back wall facing the tele. Also there's no way I want to be sticking the things 6ft high up on the wall.
    What I want to do is position them either side of the sofa at about ear level. They are Eltax bi-polars. Do you think this is a reasonable place to put them?
    Any advice appreciated...
    thanks,
    Craiglad.:eek:
  2. perrdl
    perrdl
    Jul 29, 2002
    371
    19
    Worcester
    Hello,
    As a few people have explained to me now, Bipolar speakers SHOULD be placed on side wall's and not on rear walls. Just check http://www.dolby.com and it says so!!!!
    So they should be fine!!!
