rear speaker placement
Discussion in 'Home Cinema Speakers' started by RobTi, Jan 5, 2007.
  1. RobTi
    RobTi
    Dec 11, 2003
    2,627
    Hamilton
    +158
    Hi all
    I have a pair of M|A Bronze bfx speakers that i want to use as rear speakers in my home cinema set up could someone hel with speaker placement either side or back wall and height?
    Robert
    btw system is
    Sony stra-1200
    Rel strata2 sub
    MA bronze as follows
    2xB2's
    2xBFX
    1xB centre
  2. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    Try them in both positions (about 1m above seated head height) and see which you prefer.
    Mine are on the side walls pointing towards the sofa.
  3. RobTi
    RobTi
    Dec 11, 2003
    2,627
    Hamilton
    +158
    The problem i have is that i will be sitting against the back wall in line with the speakers either side of me so how far from the corners on the side wall should i mount these?
    Robert
  4. Tokoloshe
    Tokoloshe
    Oct 17, 2006
    234
    +20
    I'd go as close to the corners as possible but keep them on the side walls facing towards your seated position.
    It would help if you could pull your sofa forward even as little as a foot may make a difference. From memory I think the surround L & R should be somewhere between 10 and 30 degrees behind you and about 6ft from the ground.
    Hope it helps
    Toko
  5. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    As you sit on the sofa, the tip of the bipole points "through" my ears e.g. I sit on the line drawn between the 2 speakers. As they are different distances (left is about 1.9m and right is 1.3m from seated position) I use the distance settings in my amp. It sounds far better than when they were in a different position - experiment and see what sounds best for you in your room.
    There are pictures on the Dolby website of speaker arrangements & positions.
  6. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    generally the sides work best for most people, pointed directly at you....however if on the back wall its worth, as people have already said, experimenting.....so try them on the back wall too.......if its at all possible, bring the sofa forward a bit even just a foot or so can be useful, that stops too much reflection from the speakers on the back wall when mounted on the side wall...
