Rear Speaker Dilemma!
Discussion in 'Home Cinema Speakers' started by acanning, Aug 4, 2004.
  1. acanning
    acanning
    Mar 11, 2002
    111
    16
    Hampshire
    Dear All
    I have recently moved house and now need to start again with the layout of my home cinema kit. I currently have the following;
    Yamaha RX-V640RDS
    Main Front Speakers : Kef Reference 102/2
    Centre : Proac something or other!
    Sub : MJ Acoustics Reference 1
    I used to have some other Kefs for the rears but they now don’t fit in my new room so I need some smaller speakers to be wall mounted. The height can not be more than about 20cm. I was considering the Kef KHT 9000’s positioned horizontally but they are a lot of money at about £500 each. Could someone advise on some cheaper alternatives. What are the Kef Eggs like? Would they be swamped by the fairly ‘big’ sound created by my front speakers?
    I’m also a little concerned that the Amp is straining a bit driving the Kefs and Proac speakers (I used to have a Meridian power amp helping out) but I guess that is a topic for another day!
    Any advice would be much appreciated.
    Many Thanks.
  2. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    I'd go for something a bit bigger, like the THX Mordaunt Short 506 Dipoles, they should be a good match for what you have already.
  3. Craig Sowerby
    Craig Sowerby
    Nov 14, 2002
    313
    +27
    Have a look at the M&K K4 tripole surround, less than 20cm high. £495
    Great room filling ability.
  4. acanning
    acanning
    Mar 11, 2002
    111
    16
    Hampshire
    Thanks for your input.
    I think that The Mordant Short speakers will be too big. The M&K's look interesting although I've never come across dipole speakers before. I am a bit concerned about the 4ohm impedance, will that cause a problem for my Yamaha amp? It's already driving the Kefs which I think are also 4ohms.
    Also, where do you get M&K speakers from?
    Ashley
