rear speaker buzzing
Discussion in 'Home Cinema Speakers' started by kazzup, Dec 22, 2003.
  1. kazzup
    kazzup
    Dec 22, 2003
    42
    West Yorkshire
    Hi everyone, I am a newbie, hope somebody can help. I have searched for a solution to my problem but nothing mentioned in any thread has worked.
    I recently installed a Vibe Alpha 11 subwoofer to my system which I think is causing the problem. I am getting unacceptable rear speaker humming/buzzing even when the amp's volume is zero. But if the sub is disconnected or turned off the speakers stop the annoying noise.
    I have as follows;
    Toshiba 36zd26p
    Yamaha A492
    Kef Q35's
    Kef Q95c
    Yamaha NS E103 rears
    Any help will be greatly appreciated.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Could be a ground loop or the cable between amp and sub.
    Try using some AC filter between sub and mains outlet.
    Also try using the same outlet as your amp, i.e. from the same feed.
    Also try changing the cable between amp and sub, perhaps a (better) shielded one.
  3. kazzup
    kazzup
    Dec 22, 2003
    42
    West Yorkshire
    thanks for your reply as i am new to this. I have replaced the lead from the amp to sub with a very expensive lead which made no difference at all. I'll try the other things you mentioned aswell, reading through past posts this seems to be quite a regular problem
    thanks
