rear speaker advise
Discussion in 'Home Cinema Speakers' started by upallnight, Nov 6, 2003.
  1. upallnight
    upallnight
    Jun 11, 2003
    1,816
    63
    watford
    +106
    okay ,a little help needed please
    i have just recieved my new front speakers
    kef tdm23f L&R
    kef tdm23c
    my rear speakers i have had a couple of years
    jamo surround 300
    should i bear with these or would i get an improvement from mission surrounds or others
    the matching rears for my fronts would be to big so i need something discreet looking(hence thinking of the missions)
    any help would be great
    thanks
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I doubt whether you would get any noticeable increase in quality by moving to Mission as they are about the same quality level as the Jamo that you already have.
    I would stick with them unles you change to the KEF TDM speakers which are of much higher quality as well as being a tonal match for your fronts.
  3. upallnight
    upallnight
    Jun 11, 2003
    1,816
    63
    watford
    +106
    ok may leave it for now
    thanks for replying
    maybe i will get a sub next then
  4. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I ran fairly expensive M&K speakers at the front and much cheaper Missions at the rear for quite a while and whilst there was a noticeable difference when I bought a more appropriate pair of rears, the difference was nowhere near as pronounced as adding a decent subwoofer.
  5. upallnight
    upallnight
    Jun 11, 2003
    1,816
    63
    watford
    +106
    the MJ acoustics sub has been catching my eye
    if not maybe a velodyne
    this home cinema lark is harder than my other half thinks:D
  6. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Ian what are you using at the back these days, more M&Ks?
  7. upallnight
    upallnight
    Jun 11, 2003
    1,816
    63
    watford
    +106
    mordaunt short 506 dipole surrounds
    how good are these:confused:
  8. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I bought a pair of M&K K4 from the classifieds here which work very well with my M&K fronts. The soundstage is much more enveloping now which I put down to them being much better speakers rather than being a better tonal match.
    I even play SACD and DVDA now which sound a whole lot better than before.
