Rear-Projection TV's lifespan: Is it short?
Discussion in 'General TV Discussions Forum' started by tk2001, Nov 25, 2001.
  1. tk2001
    tk2001
    Nov 4, 2001
    1,381
    48
    +36
    Hi, I've just recently brought the Toshiba CRT 42WH18B rear-projection TV and the picture quality is the best I could have hoped for - DVD pictures like The Gladiator are phenomenal and the PS2 and the Gamecubes games looks equally as great!
    However there is one thing that I'm very cercerned about and I hope that it can be clarified by someone who knows the facts.
    The problem is (and this goes with all CRT rear-projection TV's), is that I read that the general lifespan of these TV's are shorter than conventional CRT TV's - the 3 CRT tubes/bulbs behind the TV screen (red, green & blue) burns quicker than convention CRT TV tubes - is this true?
    If this is true, then I how long (years or hours) does the 3 tubes/bulbs lasts, and much does it cost to get each tube/bulb replace?
  2. delta
    delta
    Oct 16, 2000
    469
    16
    North East Cheshire
    Depending on often you use or abuse your tv then the lifespan is the same as any other tv and at least five years.
  3. Shady Deal
    Shady Deal
    Sep 5, 2001
    435
    Wiltshire
    Acording to an enginneer that works for toshiba they quote the expected liftime of their sets as follows:-
    CRT Tube = 6000hrs
    RPT = 4000 hrs
    So yes RPTv expected life is slightly shorter, but in real terms you should not need to worry.
    Regards
  4. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    those numbers to sound rather short .
    the understanding that i have is that the tubes in a rear po set last longer than the tubes in a front crt bases projector .
    the tubes in a front pj are said to last 10000h and over so 4000 sounds far too short too me
    in the long run it all depends what you do with the tv . realy the best thing is to use it in a very dark room with no light falling on the set . this way you can run the set at lower brightness and contrast levels .
    use somthing like videoessentials or avia to set the con and brighness , then you have a better idear of if you are pushing the tv too much
    ather things to take in to mind are . don't leave the tv with a still image displayed for any length of time (just put the set in standby if youneed to pop out the room ect) be very carfull with contast levels when playing games and finaly watch out for logos on didgital tv (these can burn in to the tubes and be permenent).
    there are a lot of rearpro sets out there that have been around for a very long time . just be aware and don't push the set too it's limits
  5. Shady Deal
    Shady Deal
    Sep 5, 2001
    435
    Wiltshire
    The numbers do indeed sound rather short, but this came from the horses mouth so to speak!!
    Maybe I should have qualified it by saying the "Minimum Expected life" is ............
    Regards
  6. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    i'm sure if you are talking minimum life you could probtake that number even lower
    you could get nasty burn in the hundreds hours of use if you where stupid (as some shops seem to be those poor tvs what they do to them) leave a static image on at high brightness and contrast for any length of time and you will be left with somthing not even worth watching star wars ep1 on ;)
