Rear-Projection TV - Any Good for Everyday Use?
Discussion in 'General TV Discussions Forum' started by chriswales, Mar 27, 2006.
  1. chriswales
    chriswales
    Straightforward enough question hopefully - are rear-projection tvs any good for normal use? I'd always assumed they were, but I was talking to someone the other day who claimed they're only any good in dark rooms. Is he confused with front projectors and therefore talking utter [email protected], or is he correct?
    I'd like a nice new big tv in my living room, but as it's going in a corner anyway have no real need for a fancy plasma / lcd. Any other options for me? What's the largest CRT I can buy these days?
    {EDIT: Ignore the budget part -just checked and I might be a fair bit off}
    Budget-wise I'm not looking to spend too much to be honest, preferably under £1000. The type I have in mind are just the general ones in Tesco etc for about £700 iirc.
    Thanks in advance to any nice people offering useful advice!
    Chris
  2. 7up4it
    7up4it
    Oct 29, 2004
    1,685
    Cheshire
    +83
    No problem for everyday use, I have a 60" sony RP TV which is superb.
    Projectors have to be used in a darkened room so they are not ideal for everyday use.
  3. Bat-man
    Bat-man
    Oct 31, 2005
    2,931
    Lincoln
    +525
    Rear Projection TV's is absolutely fine in a normally lit room.
    Front projectors require a darkened room as said above.
  4. Tarbat
    Tarbat
    Oct 15, 2003
    2,590
    Easter Ross, Scotland
    +302
    Beware, these may be CRT-based RPTVs, which may have a fairly low contrast ratio. Ideally stick to a DLP or 3-LCD based RPTV.
  5. Mark_a
    Mark_a
    May 27, 2005
    3,252
    +708
    I think all RPTVs actually work better in subdued lighting, but even CRTs and Plasma/LCDs will look bad with sunshine hitting them full in the face.
    Regards
    Mark
  6. Tarbat
    Tarbat
    Oct 15, 2003
    2,590
    +302
    I've found that our DLP RPTV is actually better than our old CRT in this respect, it copes better with daylight falling on it.
  7. Tight Git
    Tight Git
    Mar 3, 2004
    6,331
    +597
    Depends what you mean by "everyday use". :lesson:
    In our house the TV is on all day. :eek:
    At that rate, the very expensive tubes would need replacing after 3 years. :thumbsdow
    That's why I reserve my rear projection TV for special occasions. :thumbsup:
    At present, after 11 years, my tube time is just 1500 hours. :clap:
    But then I am a TG! ;)
  8. mrwicked
    mrwicked
    This is probably due to the RPTV being completely flat and most older CRT's had a slight curve to the screen..
  9. arfster
    arfster
    Jan 17, 2006
    1,459
    63
    +132
    Oddly, I actually find my Sagem better with the lights on than in complete darkness - in the latter the bright parts of the screen are borderline painful, even in ECO (lamp brightness saver) mode.
    As others have said, try get a DLP rather than a CRT rptv. The cheapest one around afaik is the LG, which can be had for a touch under £1000, and produces a pretty good picture.
  10. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,724
    Somewhere in South Yorkshire
    +6,296
    Only if, like yours, the TV is a CRT RP type.
    In case of a DLP or LCD projector, the item that needs replacing is the bulb. It's user replaceable, and new ones cost (say) GBP200-300 (estimates vary hugely, but this is the ballpark). Lifespan estimates also vary hugely, but reckon on a ballpark of 5000 - 10000 hours. The rest shouldn't deteriorate with age to any discernible degree - well, nothing that an occasional internal clean won't cure.
