M
Mr fuse
Hi I think im just about to take the leap for a rear projection tv Ive heard about the good and bad points about rear projections but im just wondering about screen burn the one thing that worries me. Im going to use the tv for everyday use in a room that never really gets much light. Im also a bit of a gamer and have an xbox and cube do you think this is going to cause a problem? im looking at the Toshiba 42PW23 as the prices are quite reasonable now the only other thing im concerned about is the stands if i get one which im going to need for dvd and cable box will this make the tv to high really?
