Rear projection - Is it worth it?
Discussion in 'TVs' started by Will18, Jan 27, 2005.
  1. Will18
    Will18
    Feb 1, 2004
    120
    I have come to the conclusion that my 28inc CRT television just isn't big enough so i'm looking into larger screens. I'm a student so my budget is tight.. so thats LCD and Plasma out the window but I did come across this.
    http://www.qed-uk.com/q?i=11_gA81Zfqb6&vp=6&bg=173&bp=q2s&bi=0
    I was really excited when I cam across this at about 9 this morning, but have been doing some reading through the day and now feeling a little down. Issues regarding screen burn, large maintenence bills has got me wondering is it worth it.
    Also I have read reviews about the picture being abit dull? is that beacuse people have been watching too much plasma and top end projectors that a CRT RPTV isn't up to those standards? Also a question that would it be safe to be moved around, ie next year when I move into my own flat/house share, would the travel damage it in anyway?
    any insight would be more then welcome, Thanks
  2. Paully01
    Paully01
    Jan 4, 2005
    9
    Hi Will18
    I had one of these & soon returned it due to poor picture quality. loads of artifacts when watching footbal & any fast paced movies. Also suffered from red & blue blurring on edges of screen. :thumbsdow
    I've now taken plunge to buy the Sagem HD45
  3. Will18
    Will18
    Feb 1, 2004
    120
    Thanks for your reply, giving me second thoughts and third and forth about getting this. Just a question how did you have it connected up? Via component, scart, rgb? Thanks in advance
  4. Razor
    Razor
    Dec 15, 2004
    37,552
    2
    +12,510
    If your strapped for cash sit nearer your current tv set. Job done :)
    Sorry I couldnt resist. Try posting in normal tv section this section is for rear dlp tv's only which are around £1500 upwards.
  5. Paully01
    Paully01
    Jan 4, 2005
    9
    Used the RGB Scart, I even had the set returned for repair still came back the same
