Rear Pro advice needed please
Discussion in 'General TV Discussions Forum' started by jds, Jul 20, 2004.
  1. jds
    jds
    Jul 20, 2004
    39
    I have £1500 - £2000 to spend on a rear projection TV/stand, either a DLP or LCD due to size constraints. I have a Toshiba SD220E and separate 5:1 sound and I assume that I should go for a TV with component video inputs (although I've been told that an RGB only scart conection will be as good). Anything else I should be considering and any recommendations? - I can wait a few weeks if there's anything on the horizon.
    Thanks in advance for the advice - please assume (correctly) that I'm a beginner!
