fazer92
Ok so looking to upgrade my sub, and that conversation brought up my surrounds and realised these are way overdue an upgrade from my first HT setup. Currently running str1080, MA bronze 50s as front, bronze c150 centre, tannoy HTS sub, and 4 HTS surrounds as 2 corner of room mounted surrounds and 2 Atmos speakers.
Will want to upgrade all the HTS stuff but first priority is the 5.1 elements so surround (sub being looked at already).
Now ideally I'm looking at 2nd hand as can't go too high on price ATM, love the look of the MA fx's but I've seen they shouldn't be placed directly in the corner. Ideally I need small speakers as the other half already hates the HTS surrounds and they are only h-16cm w-11cm d-13cm. The fx's are noticeably bigger but I feel like the design I would be able to get away with.
Main seating position is against back wall which the speakers are mounted too, with only enough space for the recliners to move back so no room for stands.
Any suggestions much appreciated, if I've missed critical info I will add
