Rear dipole height question
Discussion in 'Home Cinema Speakers' started by Mr Bump, Jun 5, 2003.
  1. Mr Bump
    Mr Bump
    Jun 3, 2003
    365
    Leicestershire
    +3
    Going to redocorate my room this weekend. Always thought that maybe my rear dipole speakers are too high, so if I want to adjust them, now is the time! :)
    They currently sit about 6' from the floor, parallel to the seating position. Seating is a standard height sofa. Is this too high? What height should they be, ideally?
  2. menalaus
    menalaus
    Apr 25, 2003
    338
    sleepy hollow
    +6
    if your redecorating anyway id bang a few nails in the wall at different heights and see what sounds good.
    this may result in a delay in the painting, Boo Hoo!
    every room sounds different so its hard to give a definative 'they should be x number of cm from the ceiling' answers IMO
  3. EN
    EN
    Jul 24, 2000
    267
    19
    Sofia, Bulgaria
    I've placed mine about 2m from the floor and they sound good to my ears.
    The room is 3m height.
  4. Mr Bump
    Mr Bump
    Jun 3, 2003
    365
    Leicestershire
    +3
    Yeah, my room is only 2.3m high. I've just tried them at 1.75m high and they seem to sound much better....
  5. Hawklord
    Hawklord
    Feb 15, 2003
    3,441
    Aldershot, Hampshire
    +265
    Mine are three Ft higher than my sitting position as recomended in two or three of my av manuals.
    Experiment though and leave in the position you like the most as I did - which happened to be what was advised in the first place.
  6. Mr Bump
    Mr Bump
    Jun 3, 2003
    365
    Leicestershire
    +3
    Does the fact that my rears are Dipolar make no difference though?
  7. Craig Sowerby
    Craig Sowerby
    Nov 14, 2002
    309
    +25
    The optimum height for your Di-polar surround speakers is fairly close,
    they should be 1.8m to the centre of the drive units.
    Hope this helps.
  8. Mr Bump
    Mr Bump
    Jun 3, 2003
    365
    Leicestershire
    +3
    Thanks Craig - is that 1.8m from the floor, I assume?
  9. Craig Sowerby
    Craig Sowerby
    Nov 14, 2002
    309
    +25
    Yes.
  10. menalaus
    menalaus
    Apr 25, 2003
    338
    sleepy hollow
    +6
    why 1.8m ? doesnt room dimentions,contents,shape, how they sound to the individual etc make a difference?
  11. Mr Bump
    Mr Bump
    Jun 3, 2003
    365
    Leicestershire
    +3
    Brilliant - thanks again! I had heard that di-polars had specific heights, so it's nice to know what they are! Guess mine have been too high for ages...:rolleyes:
  12. nathan_silly
    nathan_silly
    The manual for my dipoles says.....
    "Place the speakers at a minimum height of six feet, to achieve optimal sound and to provide sufficient head clearance. Mount the HDP-2's at least a few inches from the ceiling."
