Rear Centre - which one to choose
Discussion in 'Home Cinema Speakers' started by MadMaelstrom, Jul 21, 2005.
  1. MadMaelstrom
    MadMaelstrom
    Feb 10, 2005
    1,819
    +164
    Im changing my speakers to the M&K 150 range and was wondering what speakers would be good as rear centres to replace my current KEF TDM ones.
    Spoke to a couple of dealers and am getting mixed responses.
  2. JohnnyScot
    JohnnyScot
    Jan 14, 2005
    254
    +18
    Andy,
    I had the same problem and the only advice I got was to use another 150! Well at the cost I thought it was a pit too pricey so I scored high and low to find some S85 as they use the same mid driver and tweeter. Got a couple off here and they have been great. Just big enough for the back with no change in voice between them all.
    See set up below the the full deal.
  3. MadMaelstrom
    MadMaelstrom
    Feb 10, 2005
    1,819
    +164
    Thanks for your reply, in the end i've gone the same route as you but slightly different. I've used the SW85's and had them mounted in my ceiling, they look and sound spot on. I'll post some pics later on today of my new system
