Rear centre speaker help
Discussion in 'Home Cinema Speakers' started by Greg Hook, Jan 3, 2002.
  1. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,886
    2
    In a secret location with Jennifer Lawrence
    +9,747
    I am just about to buy the Denon AVR 3802 receiver and now need to get a centre rear speaker.
    Do I buy a speaker the same as the rear surrounds or do I have to get a dedicated centre speaker?
    Thanks for any replies.
    Greg:cool:
  2. uncle eric
    uncle eric
    Greg,
    What speakers do you currently use?
    Eric
  3. Greg Hook
    Greg Hook
    Nov 25, 2001
    22,886
    2
    +9,747
    :cool:
    I currently use all Tannoy speakers.
    MXC centre
    2 x MX2 for the fronts
    2 x MX1 for the rears.
    Plus a Paradigm subwoofer.
    Greg
  4. Guest
    it's more important that all your fronts match. I think missions 77ds are the best pair you can get for under £200 and there 77c1 centre, what hifi said it was the best centre up to £800 and it's only £200
  5. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,231
    UK.
    +2,767
    By all accounts, you really need two rear speakers instead of one.
    I tried 4 identical speakers for my sides and rears with my 3802, and I found that I had to angle the rears downwards a bit otherwise the sound they produced sounded like it was coming from the front.
    I also experimented with some HT2 bipoles from Richer Sounds, and I personaly preffered them as rears, with the monopoles at the normal side positions. I'm thinking of geting another pair of HT2s, and trying 4 bipoles just to see what it sounds like.
    I wasn't overly struck on bipoles at the sides, with monopoles at the rear, but that's just my personal choice.
    Gary.
