Rear Centre Questions
Discussion in 'Home Cinema Speakers' started by @if ®afiq, Jun 28, 2004.
  1. @if ®afiq
    @if ®afiq
    May 31, 2004
    657
    +20
    Before I go drilling holes into my wall ;) I have some Q's:
    1) My two rears are (or at least will be) 2.2m away from each other - would I benefit from a rear centre?
    2) What would be better: MS302 or MS304 and why?
    3) If you answer MS304 to no. 2 then how about using two MS302's for the rear centre channel?
    Thankyou :)
  2. Zone
    Zone
    Jun 24, 2001
    6,775
    Barnsley
    +2,507
    People would need a little more info with regards your seating position in relation to where you would put a centre rear, if your seating is flush against a back wall then no not ideal; if you have a decent amount of room behind your seating to the rear wall then possibly!
  3. @if ®afiq
    @if ®afiq
    May 31, 2004
    657
    +20
    My Seating/room isn't ideal for a home cinema.
    The rears are around 9ft behind and roughly 40cm above.
    There is a good amount of distance between me and the rears - but the actual speakers are not very far apart...
    ...I guess I could stack up some "things" to the right hieght and give that a bash...
