Rear bi-polars position??
Discussion in 'Home Cinema Speakers' started by gazzer82, Sep 22, 2005.
  1. gazzer82
    gazzer82
    Hi All
    I am new here and this is my first post, so be gentle.
    I have just moved into a new flat and am about to buy some new rear speakers, probably the Eltax HT-2's as i use the system mainly for TV and Movies so i feel bi-polar is the best option.
    However i am unsure as to where to position them as my rear wall is a bit of an odd shape. I have attached some photos so you can see what i mean. Where do you reccon i should place them (i normally site center of the sofa).
    Any help would be greatly appreciated.
    Gareth
  2. Roohster
    Roohster
    Jul 1, 2004
    2,535
    Derbyshire
    +1,259
    put 'em on the "side walls", i.e. under the centre picture and to the side of the floor lamp, level with your seating position.
  3. gazzer82
    gazzer82
    Cool, will that be ok, i was worried about reflection from the left speaker off the wall as it juts in to create the anti-alcove thing and would only be 2 feet away, whereas the right speaker would be a good 9 feet from the actual back wall? Would this be noticeable? Or would the 45 degree angle of the actual speakers negate this issue if i placed then to the angle would skim by the edge of the wall? I hope i am making sense, this is really hard to explain.
    Gareth
