really silly question
B
bazz7777777
im thinking about buying a dvd recorder (Alba RDVD1002 DVD recorder) from argos at £79.99, my question is do dvd recorders have a tv tuner built in so i can record one side while watching another side
thanks in advance
p623
thanks in advance
Yes. that is you record using the internal tuner and watch with the TV tuner as normal, works the same a vcr
Paul
