Really need some advice on Speakers
Discussion in 'Home Cinema Speakers' started by hertderg, Jul 12, 2005.
  1. hertderg
    Sep 25, 2004
    Hi - I'm hoping someone can advise me on a couple of queries I have.
    I've decided to upgrade my home cinema package from the pioneer sdv323
    to separates so I can get the best out of my new pv500 plasma and fill
    up a big space in the stand. Funds are a bit tight though after
    purchasing the plasma , stand and cables so I'm looking to enter at the
    budget end.
    The two amps I have in mind are the Yamaha 350 and the Denon
    1705 -I've not yet decided, both get great reviews, any thoughts? I can push the budget to about £250 so would consider any other models.
    The main reason for the upgrade is because of the sound quality on the
    pioneer, overall I'm very happy with the sound performance but the
    centre speaker Is the main problem, although the centre speaker supplied
    has a spec of 100W the speech is very low and hollow compared to the front and
    rears. The problem may be due to my room and layout, living room and
    dinning room is all in one and is 29ft L x 13ft W in total, my set up is
    in an alcove next to the fire pointing out into the living room/dining
    room. Having a system played at high volume is not my priority as I
    mainly watch films at night and need to consider my 3 year old daughter
    and moaning neighbours ;) The sound levels of the front speaker is a
    major problem for me.
    Thanks for bearing with me so far -
    My question is, I thinking of purchasing the amp first so would it be ok to
    hook up the satellite speakers from the pioneer until I get the funds to
    purchase a new 6.1 set, the sticker on the back of the speakers advises
    to only use them with the amp supplied or there may be a risk of fire.
    Is this a genuine warning, is it likely to happen or just spiel to cover
    Would the amp make a difference to the sound of the pioneer centre or
    should I just purchase a new bigger centre?
    Thanks for bearing with me and I look forward to reading any
    advice/suggestions you guys have.
    This forum has been of great help to me over the past few weeks. Thanks!
