Really Need Help!
bowenboy77
Hi Everyone,
I really need some help, Im thinking about setting my PS3 to tv then to surround sound via optical cable, ive only now had the courrage toask for advice, im very new to this and wanted advice on whats needed and what i need to do on how to set it up.
Whati have got is listed below
Samsung PS42A456P2D tv
Samsung HT-Z310 Surround Sound
PS3
Hope someone can guide me
Mark
ows90
Hi, welcome to AV Forums.
The connections should be (NOTE: no need to spend more than £10 on HDMI or optical cables):
PS3 -> Optical cable -> Home cinema Digital Audio IN
PS3 -> HDMI cable -> TV HDMI 2
TV (Audio Out) -> Stereo phono cable -> Home cinema AUX IN 2
Home cinema -> HDMI cable -> TV HDMI 1
Then press the AUX button on the home cinema remote control to choose AUX 2 or D.IN, for Freeview and PS3 respectively.
In PS3 Settings > Sound Settings > Audio Output Settings, set
Connector Type: Digital Out (Optical)
Output Format: Make sure Dolby Digital 5.1 Ch. and DTS 5.1 Ch. are checked.
AND
Video Settings > BD Audio Output Format (Optical Digital): Bitstream
You should also press the PL II - MODE button at the bottom left of the home cinema remote to set the surround mode for stereo Freeview broadcasts (Pro Logic would probably be best). You don't need it for the PS3 as the optical connection provides true surround anyway.
