Really need help on this !
Discussion in 'Projectors, Screens & Video Processors' started by Gadjet, May 19, 2003.
  1. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    This is the only way of deciding what to buy and is so important. I live in Wrexham North Wales can anybody give me the closest store where I can see these pj,s in action. I will have to travel!
    1. Panasonic AE300
    2.NEC HT100
    I wont be able to decide till I see any of these in action.
    Messiah, Paul or Steve another question, when the NEC 100 is in 16:9 mode how big are the black bars bottom and top? The screen that will be here tomorrow is 16;9 format 70" wide.(ordered it thinking I was having Sony 12HT
    A big thank you,
    Phill
  2. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    My phone number is , yes I am so determined to get this sorted once and for all and sit back relax and enjoy my DVD,s again without thinking of which pj,
    Phill
  3. Messiah
    Messiah
    Apr 22, 2002
    7,529
    +339
    Phil
    I'll answer your post in a moment as to black bars, it's a very simple bit of mathematics, but I would remove your phone number ASAP if I were you. Not a good idea to post yourt number on a public forum. There are some nutters out there :)
    Neil
  4. Messiah
    Messiah
    Apr 22, 2002
    7,529
    +339
    OK Phil. A 16:9 screen is 75% the height of a 4:3 (16:12) screen so the size of the black bars will be (combined) 25% of the height of the 4:3 image or 33.3% the height of the 16:9 image.
    Therefore if you have a 70" wide 16:9 screen it will be 39.375" high. Therefeore each black border will be
    39.375/3/2 = 6.5625" high (13.125" total). Don't forget that you will not see these on your 16:9 screen as they will fall outside the viewable screen area. Also don't forget that with the HT1000 you can move the 16:9 image up and down inside the 4:3 panel area to suit your screen. So, you could have your 16:9 image aligned with the top of the panel and all the 13.125" falling below the screen (it will be almost invisible).
